revomaniac
Ya it sounds like a OWB! Take off your easy start and check the bearing to make sure its still good! On the starter shaft the bearing should grab the shaft and turn the shaft in one direction. and in the other direction, the bearing should turn freely!!! Hope this helps. Also a little tip for you. When your done running your truck and you shut it off, you should set your piston at BDC(bottom dead center) this will keep your piston and cylinder tight. You should also spray WD40 or after run oil into your engine and carb. I also spray a 2 second burst of Wd40 into my gas tank after each run so if theres a little fuel still in my tank it doesn't gain to much moisture. hope this helps
