I run 16/38 in my 21TM revo, but I probably have lighter wheels/tires on it. I put a set from the v1/2 kraton just to try out and I liked them over the traxxas geode/chevrons I had on it. I have full RRP steel in the transmission with the standard ratio gearing. Pretty sure I'm running a dynamite maxlife 2 shoe clutch on it and a THS low end small block pipe. It wheelies pretty easily. I had lower gearing (15/40) on it, but needed more speed to clear some jumps at a grass bmx track I run at.
I don't have the full integy cage, but I do have the integy 4 point motor cage on it. I'd put a 1/8th clutch/flywheel on it, but I got it used many years ago and it came with MIP center axles. To put 1/8th clutch on it (instead of the alloy 2 shoe), I'd have to move the transmission forward 1/4" like I did on my big block revo (LRP28 in that one), then I couldn't use the MIP's.
How heavy are those tires? Maybe they are sapping away a decent amount of power? Are you running the standard ratio or the wide or narrow ratio in the transmission? I think the 1st gear is the same for those, but 2st gear is higher or lower than standard, so shouldn't really matter for wheelies, just acceleration when it shifts.
For what I do at that place, the close ratio would probably be better to give me more grunt in 2nd and allow harder acceleration.
This was the last time I ran it with 16/38. If I remember right, the grass was a bit wet when I started, so it spun quite a bit.
