Revo tires on a Maxx
They work, except that they do not let the wheel nut thread in enough for the lock to start to grab the threads.. So, you have to keep checking the screws.
I did try everything else and they and they still hit. I have another servo arm that I want to try, but I broke the screw off in the servo gear.. I have a replacement set of gears on order, but for now I used the platic gear from a 2055 servo and it fits inside the HS645MG servo as long as you use the 2055 bronze bushing on the bottom of the gear and the bearing on top. The arm I want to use won't fit the 2055 gear though.
i have revo tires and wheels on my maxx truggy and i havent had any problems i must have luked out
I think it's a combination of the servo horn and the wheels/tires. I've changed servo horns and everything seems ok now.
Curious about how you truck handles though, mine will roll over on command if I turn to tight.
are you running stock shock towers
eathier way your probly running to high so that it makes you top heavy
you could eaither drop you chassis lower to the growned of try to by longer a-arms to give you more wheel base for stability
lyle
