Thanks guy’s, my guess is that it overheated for less than ½ minute. The engine still has compression and seems to be ok (have not run it yet)
After the overheat I did set the piston to BDC and let it cool. I always use WD40 after I run and am very pleased with the results. Never problems with starting the next time.
The Picco Reddot seems to be out of stock everywhere at the moment so I will order it once it is available and then use my 3,3 for winter running. As far as I can understand the Reddot should be a direct replacement for the TRX 3,3 even the rear pipe set up. I use a roto-start so I'm not so worried about the EZ start.
