Hmmm...certainly sounds out of balance. Is the wheel glued all the way around or spot glued? If spot glued, did you glue it evenly...as in spots like lug nuts on a car's wheel, balanced around the edge of the rim.
It is also possible that the wheel is not tightly on the RC...make certain it is on the hex all the way or whatever the REVO has to keep the wheel on the axle and that the wheel nut is tightened all the way down. A loose wheel can cause the RC to wobble when airborn.
It is also possible, but unlikely, that your one wheel got some water in the foam or got crunched up unevenly on the rim while you were trying to glue it. This would cause the wheel to be unbalanced, and thus the ride to be unbalanced when airborn.
All of these can be corrected without buying a new wheel...but buying a new pre-glued wheel is also an option and entirely up to you.
