REVO-5309
So i figured there are a fair few cage/hoops out there and i thought id just make my own. basically going to replace the factory hoop with steel and weld nuts to the bottom so i can still mount it the same way. will be welding nuts to the underside of the top of the hoop so i can countersink the screws that will hold the bars that protect the exhaust.
btw i dont have a vice so its a bit hard to bend and keep straight lines. ill finish it all up before i weld it all together and try straighten it up as much as possible.
pics of progress.
steel purchased
heating and bending in progress using some heat beads in a small container
side by side
plastic hoop
new steel hoop
main bar coming from the rear
before it got dark i managed to finish the engine/manifold side.
tomorrow i hope to finish the fuel tank side. once that piece is done ill put another bar across inline with the exhaust but behind the motor (almost where the green tape is atm) so the motor can still be removed with the cage on. not sure how I'm going to mount it to the rear yet. might make up a thin plate that sits between the rear bumper mount and chassis, drill holes in it so the screws can still go through and weld the cage to it.... or just weld a small plate on the end of the bars and drill a hole in the plate and just screw it down. not sure what will be more secure but i have till monday (when i go to work to weld it) to decide.
pics of progress.
steel purchased
side by side
plastic hoop
new steel hoop
