Revo BB Kit Please Help
jasminemy4g63
RCTalk Qualifier
All you Revo lovers such as myself I need some serious help any ideas would be greatly appreciated I love my revo but hate traxxas motors so I installed a bb kit to put my wasp 28 off my old savage on it and the rotostart is in the way of the rear arm so what can I do other than a bump box or different motor is there an easy fix Please Help
The best thing for you to do is get a direct swap upgrade like the Sirio .27TX kit for Revo...You can still use the flywheel,clutchbell,muffler and ez-starter.It comes with mount and manifold along with engine..The only other alternative would be to try to stick a pullstarter or Tiger Drive on the wasp engine..Good luck
Get a mount that puts the engine up higher like the new era mount:
http://www.neweramodels.com/item.cg...i-bin/inccatalog.cgi?session_id=&part_id=2553
It's what I ran on mine when I had it with an XTM 24.7:
Still have the mount and wire I made for the throttle I think laying around here... $35 via PP shipped in the US gets it to you if your interested.
Found it while typing:
Thanks
Thanks soon as I get some money I will paypal you but it may be atleast 2 weeks Are you interested in any kind of trades I have a lot of rc stuff that I'm trying to thin out all I'm keepin is my hellfire with axial 32 and this revo let me know what your lookin for I may have it thanks Larry
New era mount works, but you also have other options.
Get an aftermarket swing arm and a rotostart or a quick start.
Swing arm link: 28 bucks
http://www.hobbyfever.com/product_info.php?products_id=4036
Quick start link: 10 dollars
http://www.hobbyoutlets.com/store/hobby/dtxp6033-duratrax-super-start-back-plate.html
One way bearing link for quick start: 10 dollars
https://www.toysonics.com/duratrax-one-way-bearing-for-recoil-starter-g-27cx-dtxg0637.html
Rotostart link with starter: 42 dollars
http://www.rcplanet.com/HPI_Roto_Start_System_Nitro_Star_p/hpi87130.htm
Wow thanks that sounds like a really good idea already have the roto start but didnt know about the swing arm I was almost tempted to shave my arm down but wasn't sure how much it would weaken it thanks a lot What startsystem are you using in that pic Nice job by the way
Hey Doug can you please email me some pics of your revo so I can get some ideas for mine [email protected] thanks for all the help I knew there had to be an easy fix
New era sells that notched arm as well I believe:
http://www.neweramodels.com/item.cg...i-bin/inccatalog.cgi?session_id=&part_id=2696
Although, it says it won't work with a 28... Yours is really close to rubbing.
Oh, I noticed the hot racing ones you linked too are notched to create an offset to put the wheels back further to give you a bit longer wheel base.
The only downside is that it puts your header right there by the arm on full compression, so it may not be as easy to run a side exhaust. I wanted the side exhaust which is why I didn't mind the new era mount. I was tired of smashing my headers in the stock location with the small block engine in there. What header is that that you have?
