It isn't what works best that's the issue, it's lack of room. The revo doesn't allow for the extra 1/4" you need to install a 1/8th clutch.
This is how a savage flywheel/bell look on a revo without any modifications:
That was my first revo and I got tired of melting stock shoes with the 18TM I had at the time. I elongated the trans mount holes and where the brake disk floats to move my transmission forward 1/4" or so to give me room to run a 1/8th clutch on it.
When I moved the trans, I drilled a couple holes to run bolts through (with a nut on top) to key the transmission to the chassis so it wouldn't slide back on a hard hit:
The NE big block mount puts a big block crank in the same spot as the small block crank, so you still don't have room to fit a 1/8th clutch in there without moving the transmission. Well, unless you add shims to the mounting flanges on the NE mount, which I didn't want to do as it looked a bit janky and like it would flex more.
I did the same on my current big block revo. Although, on it, I'm using a mount made by a guy on this forum as he gave me a free one for loaning him my big block mount so he could make them:
It's a solid mount vs adjustable like the NE one. Still, I have the trans moved forward 1/4" or so and I'm running a savage flywheel/bell/alloy shoes on it. I've since redone the header a little bit as when I cut/bent that one, it nearly kinked it. The THS big block header was intended to be used on the traxxas big block mount which sits a lot lower as it doesn't allow the use of any big block with a normal starter on it to clear the arm.
