:surrender
Got a revo with OS .18 changing to Picco .26 max i thought this was a drop in the first thing i see is the offna motor mount # 51531 is crap it has no slot in it for adjusting the mesh between the clutch bell and the spur gears ??? also it is a thin cast alum. part is there another mount that is made from machined alum. {that has a adjustment it would be stronger and let you use different gears} .... BLA BLA BLA that was my main question . anyway i have had this for over a week still havent seen it run yet i have a 15t clutch bell and a 36t spur gear when you try to adjust it is very tight between the two you should have the clearance of a sheet of notebook paper not on this one !!! any advice what have the rest of you guys done to make this work ???:constipat:constipat
