Reverse module, is it broken ?
daakeung
RCTalk Qualifier
Guyana
Hi everyone, I switched my truck into reverse and it just revs, but when I put it back into forward it works, soooo when a reverse module *breaks* does it stop moving completely or just the reverse part stops ?
Keep in mind the reverse was working 10 mins before and the server is pulling and pushing the slider all teh way out.
It's probably broken, the truck needs to be completely stopped before shifting. Also check your servo endpoints after you get it fixed.
I know it has to be completely stopped, I always do that. It was stopped in grass and I engaged it to back out. |
But even if it's broken, the forward suppose to work still ?
A friend of mine had that happen, although, his forward would disengage constantly. He cured the problem by removing the reverse mod figuring he didn't need it for racing anyway.
well I took it apart, and it seemed that some sort of metal bolt rip through the reverse module, dang...money down the drain.
