xmodrelic
Ok so I crashed it, and pretty good too. The only thing i thing i could have hit I did and wrapped the front around a sign beam. And I mean wrapped, the front bulkhead exploded, pieces of plastic where showering down 20 feet away. I lost both upper front a-arms including pins and one pulled thru the knuckle, the front bulkhead in in 10 pieces(even the aluminum front piece is bent), the diff is leaking, the entire steering system is shot including both servos(ones striped the other is stripped and had the nub sheared off), and lastly I could not find the bumper.
So most of the stuff is on the way, but I have a couple of questions about the diff.
Any tips on rebuilding it? Its leaking and the case was damaged. I have a new case coming but is there a gasket set I need? And will I need new diff oil? Should I just buy a new one?
thanks
edit: also I'm going to need extra screws what do you guys think of this universal set,
http://cgi.ebay.com/200-STAINLESS-S...0QQihZ009QQcategoryZ44028QQrdZ1QQcmdZViewItem
thanks
