wezz
Hi ,
I have a Kyosho ST-RR , which i want to use Cody King's base set up for this truck that i have found a base set up sheet on Cody King web site. On that sheet ( http://www.codykingrc.com/category/st-rr/ ) it was written 123mm rebound for front suspensions. I changed the oil and made the rebound 123mm on the front suspensions and than put the blue springs . But after putting the blue springs , the length of the suspensions from top the bottom become 129 mm but according to the set up sheet it must be 123mm so that i change the droop screw adjustment and make the length of the suspension 123mm after attaching to the truck. The question is that am i doing the right set up for the suspension rebound.
I will be glad if you can answer.
