well i finally got it to do the blue screen and after it did, it took a while to write it all down, but i got it, here it is:
A problem has been detected and windows has been shhit down to prevent damage to your computer.
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then Select Safe Mode.
Technical information:
***STOP: 0x000000D1 (0xFF9F1000,0x00000002,0x00000000,0xF7BAB4B3)
*** cmaudio.sys - Address F7BAB4B3 base at F7B867000, Datestamp 3dd89c0b
Beginning dump of physical memory
Physical memory dump complete.
Contact your system administrator or technical support group for further assistance.
that is what it said. Judging by the cmaudio.sys it is from the soundcard. tell me what you guys think I should do. Thanks a lot.
-Pat
