Yes it will, it has a high silicone content piston machine out of billet aluminum, this makes for a very hard piston over the conventional cast pistons. It has porting you won't see unless you spend a few hundred more, the triple exhaust port really helps this engine perform. Not many engines can outrun the picco, modified it will stomp on $500+ engines with ease. It's my top pick for this price range, 90% of the engines I mod are picco and I back them 100% as they have the lowest failure rate I have seen, even fully strung out!
