Back tracking the first time I made the buffer I forgot to photograph the stages. I made the first buffer from cut stock, which meant that I had a nice piece of metal firmly clamped in the chuck when I needed it. The problem with this is that it’s wasteful of metal leaving a fairly useless ‘puck’ of metal at the end. So for the rest of the buffers I wanted to establish a process by which I created less waste.
For the brass part this was quite easy because I was able to cut the stock to length machine one side then flip it to finish the other side.
Machining the cylinder side first, cutting the cylinder to 19mm diameter and the mounting flange 25mm.
Then drill out for the cylinder bore, finishing with the end mill to create a flat bottomed hole 12mm in diameter
Next flip the part holding the machined cylinder in the chuck making sure not to over tighten
Then start reducing the other side to create the spigot for the M8 male thread.
Once down to final diameter I can use a die in a die holder in the tail stock to get the thread on square
Turning to the buffer piston this involved spinning and centring just slightly less than 1ft of 2” diameter steel bar in my mini lathe. All in the interest of saving a few inches of bar.
Turning down the 2” to just under 1/2” remains a wasteful action which I still don’t feel great about.
Then into the band saw to cut off
Gripping the narrow diameter section I was able to carefully face off the large diameter, then flip it around to create the bore for the buffer return spring.
Below I’m starting off the M3 thread in the bottom of the spring recess to retain the central retaining rod.
Now all I need is a better method to reliably cut the male M3 threads on silver steel rods, if I ever do this again I might use mild steel instead.
I’ll not bore you with any more buffer building, anyone know what I can use the gold brass dust for? :0)
P.S not sure why I have duplicate images here at the end, I have tried to delete them.
