Ran the Redcat Rampage today
Warrior4Jesus
RCTalk Racer
ran a tank through today and very pleased with the result. No breakage but no wrecks either. Nothing rattled off and no burned up electronics. I will say that if i had not checked out the servos and adjustments first i probably would have burned up the steering servo. I had to re do the end points as the servo goes farther than the truck can physically steer. I'll let you know when I'm able to get full performance.
Truck kept stalling when slowing down to turn. Found that the tension spring on the idle screw was weak. Tiny bit of blue loctite and all is well. Still enjoying my big ol awesome truck.
Screwed up hit a curb too fast at a bad angle and broke one of the adjuster bolts for the camber adjustment. Welded it back together and good to go more fun time yay!
