beason
Bash, Fix, Repeat..
this weekend i was trying to repair a shock on my hyper.. well i had to take it apart a few times.. each time having to let it set to get all the air out of the oil. i found a shortcut that may even help the racer guys if you have to do a rebuild between heats. i took the shock body and lightly clamed it in some vice grips (just to hold it) then set my trusty hair dryer beside it blowing on the shock body. this heats up the oil which in turn makes it thinner which lets the air bubbles surface WAY faster.. you still need to move the piston to release the air under it, but mine went from white bubbly oil to chrystal clear oil in about 5 min as opposed to a few hours or more. i didnt run the dryer that long, just enough to get it hot, then shut it off. these were metal body shocks so it may not work as well with plastic ones.
just a little tip I've found. if its been posted sorry, i havent seen it.
