Questions bout NTC3
NITROtooFUN
Where can I find aluminum arms for the NTC3?
I want to upgrade this car to the max.
So who makes the best hop-ups for this car?
Thanks
Do they make aluminum control arms?
What hopups do yall recommend me get first?
Should I get the carbon upgrade set?
Is there carbon fiber shock towers availabe for the NTC3?
Is carbon fiber and carbon graphite the same thing?
K-Factory makes good NTC3 parts, BMI also make the best chassis
& the fix for the shock towers. Stay away from alloy suspension parts as they bend with a decent hit, at least plastic flexes a bit. The carbon stuff from accosiated is very good it will brake easier than stock but at least if it is broken you can fix it cheaply where as a bent alloy arm may not look bent but your car will handle like poop. Alloy bumper mounts & centre bulkhead, bearing cap, diff cases etc are OK if that sort of thing floats your boat.
one of the better thing you can get for the car is a good steering servo and a 6volt nimh rechargeable battery pack and get away from the 4.8 volt the AAs give you. I noticed the difference on On-road and off-road vehicles handling.
