How far will it open if you take off the throttle return spring? The revo's TRS is known for being far to stiff for the servo on that thing and the linkage setup. The spring is stronger than the servo and if you get a servo that can push it, the wire bends. At least that's what I ran into.
Getting a more "typical" TRS and changing your linkage so your servo pushes the throttle closed will allow it to work better and still be safe.
First take off the TRS and see if the servo will open the throttle all the way. If it won't, then you will need to fiddle with the arm on the carb and possibly rotate the carb itself to get more movement.
Even then, I'd suggest buying a new piece of threaded end wire, a small captured ball end for the wire, a couple collars and a spring to do this:
I had to grind a little bit away on the pivot arm to clear the ball end, but the throttle worked really well after wards.
To get a bit more movement out of it, turn your little throttle arm on the carb like this yellow line:
Just make sure that at WOT, the little arm doesn't slip out of the slot.
I ended up switching out the servo for a 645MG. More torque for brakes.
