I was only set on WLToys A959-B because it's the cheapest and fastest 1:18 scale out there.
i would almost recommend getting a 1/16 exceed/redcat/hsp (they are all the same thing), 93$
https://www.nitrorcx.com/1sctr.html
they are very easily upgradable (they use the industry standard motor/esc/ receiver) and you can get parts for cheap. they are semi durable.
they do start out brushed, but you can easily swap in a cheap brushless combo to get more speed
speed is fun, but it does cause things to break especially being new. definitely learned that lesson multiple front ends later.
or maybe even one of these: 180$ BL 110$ brushed.
https://www.nitrorcx.com/1elrctr3.html
the brushless versions are quite a bit more upgraded from factory than the brushed versions, and i recall reading where it would be more efficient to just but the B/L version if your plan was to eventually go brushless with it anyway.
here was the post:
https://www.rctalk.com/forum/threads/tacon-soar.125935/#post-1246005
WLtoys vehicles just dont seem to be as hobby standard for upgrades and replacements. like the wheels and tires, the 1/16 exceed has 12mm hex, there are so many wheel and tire combos that fit 12mm hex between on-road tires, off-road tires, and even buggy tires.
the electronic components on the WLtoys cars seem to be almost molded in place and combines, so if anything goes out you are reduced to only replace with stock, very little upgrade-ability.
