CessnaDriver
Hello fellow R/Cers.
My Mugen MBX5 ProSpec build is going quite well and is starting to take shape and is actually starting to look like a buggy.
I will post pics soon.
I am at a point in the build now to where I need to install the servos. I will be using the JR 8800T (188oz/in & .15 sec/60 degrees)& the JR 8800S (105oz/in & .08/60 dergrees).
My question is which servo should I use for what?
Logic says to use the high torque servo for steering and the high speed servo for the throttle/brake. However I was also thinking if I use the high torque servo for the throttle/brake, then I would have plenty of brake power without the worry for fading.
Also I was thinking that the high speed servo with its 115oz/in is still quite enough for the steering.
What do you all think about this? Comments? Suggestions?
P.S. As far as the build is concerned, so far it has been solid and a very high quality kit, with the exception of two things that I think need improving.
The first being the piece that the big,chrome, metal set screws go into on the front upper control arms. That plactic piece should be metal also and then require loc-tight. It was a bitch to get those big set screws in there straight all the while trying to not strip the plactic threads.
The other being the plactic side guards that attach to the chassis. The holes where you put the lock nuts in are not snug and before you can tighten the screws, the lock nuts strip and goes around with the screw. I had to take a pair of needle-nose pliers and press the plactic down real hard to get enough of a grip on the nuts to keep them from turning with the screw.
Other than that I am real satified with this kit.
