Since you asked:
To strengthen the spine of my T-Maxx and protect the undercarriage, I have aluminum bulkheads (Hardcore Racing), titanium bulkhead braces, aluminum chassis braces, aluminum center skid (TRAXXAS) and aluminum steering servo skid (Dynamite). I have aluminum bumpers but kept the stock plastic bumper supports. This gives my T-Maxx a rigid spine. When you take the braces, skid and chassis plate together...get a pretty solid box beam right in the middle of the chassis plate. This greatly reduces chassis flex.
I have aluminum upper A-arms(Dynamite-on sale), kept plastic for the lowers, and titanium hinge pins (Hardcore Racing). This gives the four corners some strength and allows for the fact the lower A-arms take most of the abuse during off-road running (lower to the ground and thus more apt to get direct impacts from high terrain and the like). I further strengthen the four corners with aluminum knuckle joints (Power Line-inexpensive), titanium pillow balls(Hardcore Racing), aluminum pillow ball caps (TRAXXAS), aluminum wheel hexes (TRAXXAS), titanium turnbuckles (Lunsford), and a set of CVDS (MiP).
Working the suspension I have a set of AE aluminum shocks with Trinity Blue springs for the four front and two of the rear and a set of Trinity Black for the other two rear shocks. Add some aluminum shock towers (Hardcore Racing) and I have a rock solid suspension. Since you will ask, I use 60 wt silicone to fill the shocks.
For the drive train, I have a vented flywheel (RRP) and clutch bell (Racer’s Edge) on my Fantom .15FR. I run the RRP steel slipper disk set up on my steel spur gear. The tranny and diffs are stock. I have kept the center drive shafts plastic (my weak link). So far I have not toasted a tranny or diff gear. I have blown at least one center drive shaft (over-torqued in all cases) and sometime both during my bash sessions. These are cheap and easy to replace. Why not metal diffs and cases? Why not for the tranny? Haven't toasted either yet; so I'll keep my weight down by running stock.
Power plant: I run Fantom with pull start (the only thing I've broken on the Fantom and they replaced it no questions and free of charge). I run the Traxxas tuned pipe with port matched stock header (TRAXXAS). I have the 17T clutch bell and 72T spur. What do I get? A heavy duty T-Maxx that jumps off the line and climbs great. Yes, I lose some top speed, but I consider 35 mph pretty damn quick for a near eleven pound T-Maxx.
Some miscellaneous upgrades. I have a titanium drag link. I run the HiTec 5645 digital hi-torque servo for my steering servo with a Kimbrough servo saver (upgrading to the Pro-line steering kit this summer). I have the stock steering servo pulling throttle and break duty. I have aluminum servo mounts (they were on sale and looked nice). I run a HiTec Lynx 3D radio with spectra module and Novak receiver (I'm crystal free with up to ten models programmable in the FM spectrum...color me happy).
The rest are standard, upgraded air filter (Motor Saver), fuel filter (Dynamite), little things like that. Mix of black oxide and titanium screws (hex drive and socket heads for almost all screws)
Fuel tank mod-use fuel tubing on the legs to act as dampeners (I know not a metal upgrade, but you wanted all mods). This saves you from cracked tanks. While you're at it remove any primer you have and seal the hole. This will save you from air leaks down the road.
Yes, my T-Maxx is a mixed bag of goodies, but they all work great together to make my T-Maxx a veritable tank. I have broken very few parts and have tried pretty hard to keep it that way. Long answer to your question, but you asked.
