Actually, GN; the GT chassis is shared common across all models. The only two styles of Chassis are "Tub" (old style), and "pan" (new style). The GT2, which is yet to hit the market, looks like a hybrid pan/nose plate style.
However, the engine mount is slightly different between pullstart and bumpstart (thanks for reminding me of that).
So, basically, to clarify;
Differences between Pullstart and Bumpstart:
- Engine mount (pullstart mount is lower under the pullstart housing to allow for clearance)
- Exhaust Header (PS version curves up and around the pullstart to clear housing)
- Flywheel (PS version is slightly larger, altho, you can use a bumpstart flywheel in a pinch. You just can't use a pullstart flywheel on a bumpstart truck, or it will stick out of the opening on the chassis)
The engine also needs to be a short crankshaft version (usually denoted by an S in parenthesis). If you buy the long crankshaft version, you will need the Cutoff guide nut that AE sells (about $1.50). Simply thread it on all the way, make your cut, and remove.
Finally, you will need a rotary carb on the engine, as the stock linkage is configured, by default, for rotary. If you try to mount a slide carb, you will need to redo the linkage. Associated has instructions buried on their website detailing the steps.
edit; if the truck has a pullstart engine already in it, don't worry about getting parts. Here is the tower link to the engine that you'll want:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGGP7
You will have to cut the crankshaft off flush with the nut that is on it in the picture. Otherwise, direct drop in!
