putting revo 3.3 or tmaxx 3.3 gear on monster gt
alienman86
indiana
i was wondering if the traxxas revo or tmaxx gear would work for a monster gt 4.60se I'm talk about robinson racing steel forward only kit. please help
because i would like to have metal gear and they have wide range ratio
Metal spurs aren't good for anything but sending shock-load into the tranny. If your having problems with plastic spurs, your mesh is off or there's a binding issue. Bad clutch bearings could be an issue, too.
mgt trans
no i dont need spur gear its the trans gear i would like to use.
I see. Probably not. I couldn't see two different manufacturers using identical tranny internals. You probably won't get many replies on this one; people tend to use the right parts for the job they're intended for. If you have the gears, take it apart and see what you see.
mgt trans
hey do you know if the 8.0 trans will work with the robinson racing 54t dual slipper because i thank the stock one is junk. and put the pinion gears from my 4.60se will that work.
