Push Rod Question.
Bkyd Basher
Stamford Ny
Comparing the new Aluminum pushrods to the stocked there is quite a bit of difference in length. Should i use the small red spacers from the stock ones? And on the package it says to use on the LT and the progressive 1 rockers, but on the rod its says p1 p2 lt. Am i ok with the p2s then? Thanks.I'm asking because i lost even more ground clearance.
i just put a set in the rear about 10min ago, i swapped over the spacers. I'm thinking I'm going to pull apart my shocks again and put the #3 pistons in as the thicker shock oil hasnt made too much of a difference when it comes to bottoming out.
I just only have like maybe 2 inches of ground clearance, maybe less. Which Rockers should i b useing, any ideas?
