Pull Start
RevoMatic
After getting feed up with the ezi start system on my OS21tm i installed a pull start but now have dramas getting it started. Tips or advice anyone....plz
Thanks.
You need to have a very good tune on your engine to use a pull start, short,fast pulls is the best way to use a pull start, If the engine is tuned correctly it should start on the 2nd or 3rd pull.
What both of them said. But I suspect you can't get it primed. This is why I use an electric fuel pump on a flight caddy. I pull the fuel line off the exhaust and plug the Dubro fitting into it. Light the pump off and in about 2 seconds I'm primed. If you're trying to prime your engine with the pull start it will take forever if not at all.
Sent from my MB886 using Tapatalk 4
Put your finger over the stinger and give it a few tugs and it will be primed
I have duals with 4 outlets so not possible. ;)
Priming is simple. Pull the fuel line off of the pipe and blow into it, takes about 3 seconds.
