Ok, I got my Swift today and have spent most of the day working on it, So far I've put my MBX-4 upper arms on, Rebuilt all the CVDs and Rebuilt the Front Diff. First impressions where quite good, But after spending time with the car it was obvious that it wasn't up to the same build standard as some of the other cars, I don't think its as good as my H7 was but better than the Crono, Also I was not remarkably impressed with the diffs, They looked tiny and not very durable, Also they where made from untreated steel and already showed signs of rust, My Crono diffs where the same. I also noticed quite a few of the screws have been stripped on the underside of the chassis, They certainly do like using loctite! Shame they can't use any on the drive pin securing grub screws for the wheel hubs, One was actually loose completely!, Also I don't like the brake disks, They are made VERY thin, Almost like tin foil and the pads where also not that much better, They two where very thin. Finally the only other thing I did not like where the shock caps, Mounting the solid aluminium shock cap on a aluminium ball stud is not that great of an idea!, I am sure I can sort a fix out for this though. Those are the bad sides, And they are, I have to say relatively minor, Things can be replaced aslong as they aren't too dear, Overall I would say the car is definetely worth the price tag and then some.
