problems with m.p sterring
  • Thread starter Thread starter hb1111
  • Start date Start date
H
hb1111
Guest
i did the m.p sterring hop up and now my turning radius seems worst then before i did it just like in the post,but mine hits the diff case so seems to limit it from going all the way did anyone else have this problem going to mess with it a bit later but figure i'd ask? thanks
I've done the mod, never had any problems, but it probably helps that I have EPA's on my radio too...
Mine does not hit anything. Did you do it like this:
check the bar that connects to the steering rods I think you installed it wrong. Done it myself one time
mine hits the plastic on the diff housing when installed the dog bone slides right underneth it so when it hits its at max turning which is not to good,i have the bar facing the right way thanks
olds97_lss said:
I"ve bought stuff for my maxx from integy and it's soft... too soft for this stuff.
The alloy bar I am using from them does not have this problem.
hb - Can you post a pic of what is happening?
The arms themselves are what is hitting the diff housing. Mine did the same thing. I ended up grinding a little off the edge of the arms that were hitting to give it more clearance and now it works fine.
