Priming?
I pull the line off of the exhaust and blow into it until I see the fuel get to the motor, then pinch the line off while I reconnect it. Usually fires up right away when I do that.
Pull it a couple of times with the exhaust plugged. If your using an electric starter, get all ready to go and prime it as you start it. Just a couple 1/2 second touches on the stinger is all it should take. It's a lot easier to flood an electric-started engine.
just as said above, plug your exhaust hole on your muffler for a few seconds as your trying to start it, then let off the exhaust hole then it should fire right up.
thanx ill try that tonight,let you know how it went.
