Generally, the longer you make the tank to carb line, the richer you will have to set your needles and vise versa. Follow the manufacturers recomendations on the pressure line length or method and you'll be fine. Anywhere from 6-8 inches is plenty for the pressure line imo. The carb to tank line will vary depending on how you route it and if you choose to run an external filter or not. Make a couple of loops in your pressure line to help keep the fuel from the tank out of the pipe. AE recommends this and so does Team Losi.:thumbup:
