FastEddy said:
For the most part you wont be rebuilding a $30 motor.
The motors that are used in racing go from 50.00 to 300.00
If you can rebuild a 50.00 motor for 10.00 4-5 times its worth it.
Do the math if your motor costs $150.00
Some races hand out a motor for you to use. If you tune it up you will have the advantage over those that don't.
Amen, Brother Eddy!
Definately get a Hudy, as Diver recommends. I personally have the Team Cobra Pro-Comm 2K. I love it, but it's a BEAR to use unless you check tensions between each pass. Hudy's, on the otherhand, excellent. Given the chance, I'd moon the Pope for one.
redhatman said:
so what all would I need to do a sucessful rebuild?
Basically, you're going to need the following;
1. Lathe (obviously)
2. Comm Cutting Fluid (this is basically a light machine oil.. makes ALL the difference in the cuts)
3. Motor spray (any will work, so long as it's ELECTRIC motor cleaner. Anything else will eat the epoxy in the windings).
4. New brushes (possibly springs, if the tension seems to be fading).
5. Small screwdriver
6. Power supply for the lathe (4 cell pack works perfect, but I have a power supply that outs' 5v dc)
7. Bearing/bushing oil
8. Time and patience
It sounds really difficult, but it's not (at least, it's not to me...). The whole key is going slow and smooth.
If you can get someone to take you under their wing for the first couple cuts, you'll be amazed how easy it will be (once you learn).
And, as Eddy said; the cost vs performance benefit is amazing. I went from being lapped multiple times to hanging with a guy that was sponsored, and the biggest factor was the lathe, hands down.
