pls help with clucth shoes
nemesis20
RCTalk Qualifier
i have been trying to install my three shoe clucth on my 4.6. it seems to be binding against the clucth bell. i know I'm doing something wrong i can't just figure it out. anyway here is a couple of pics of my shoes installed. any help would be much apreciated.
sorry if pics are kinda blurry. i dont have a good cam. thanks all
okay it looks like you them on in the right direction, and now you need to swing the spring back. you'll feel the tension when you do it right. the spring tension should go in the half pipe looking part is where the inside of the spring should go. once in there the spring should have tension when you pull up on the clutch shoe and the bell should slide over it and spin freely. heres a pic . i believe this is the only part on the manula that isn't clear. i had problems myself at first.
Installing the Clutch shoes wat the hardest part for me while building the MT2 SS. Use small pliers and well ehm fiddle a bit, it should work :|
thanks for the help guys.i finally got it on right.bugnout thanks for the good link. thanks again all i apreciate the help.
