please help..!!!
StevoRevo
Australia
ok so i had it tuned to perfection.. well at least the best I've had it so far.. even got it doin wheelies.. well that was yesterday.. now today i was driving for about 5min and i noticed it slowly started to loose pwr.. then by the end of it the engine was still reving but the truck was not moving.. anyway i checked clutch, slipper tighness and mesh and tranny gears.. all were great.. like new..i dont know what to check next.. what else could it be.. thanks everyone in advance :)
Did you check the driveshafts as well? Sounds like you checked most of the common items already.
When the spur spins and the engine runs, what else spins? Can you see the center shaft the spur is on spinning? Can you see the center axles spinning?
Once you figure out where the power stops and things stop spinning, that's your answer.
