Platinum Revo Upgrade List
Revo Lover
K-Town, Ont.
Found this on a few other forums so some may have seen it but for those who havnt here you go!
[] = part it replaces
5324R [5324] Receiver box ($8.75)
5335X [5335] Black chrome bumpers f & r ($10)
5266 [5264] High volume air filter, inc foam & mount ($14)
5334R [5334] Axle carriers, for oversize bearings, 2 ($10)
5180 Bearings for oversize axle carrier, 2 ($4)
5353X [4954] Alloy wheel hubs, 17mm splined, 4 ($25)
5363X [5363] Fuel tank 150ml ($16)
5340X [5340] Spring mounting header ($20)
5461 Variable shock damping kit, s/s valves ($7)
5343X [5343] Long throw steering stop ($3)
5325R Throttle servo mount ($4)
A couple that I couldn't work out what was new...
5378X [5378] Pivot ball caps, 2 packs required ($6.75)
5458X [5458] Yokes, diff & transmission
Don't forget, the Platinum Revo has a different chassis plate, red aluminum suspension links, vented front disc brake, a center differential, rear brakes, no EZ start, a larger flywheel to be used with a starter box, and a few other things also......
I wonder if they found the mods lounge down there. Can't we create an autolock to old threads say if they are a year old or older with no replies it autolocks to keep the zombies locked down in the basement with the pantless ones.
