pico 26 settings
viperdog
What are the settings for the pico 26. 10-11.5 out on the low needle? that sounds like a lot. How does it come from the factory?I just can't get my 26 to run very well.
Picco 26
Pull the low speed needle and check the orings. Mine ran extremely rich even with the lsn adjusted all the way in and found the orings damaged. This was on a brand new motor, I have read others are having the same problem. I have yet to try to get replacement orings and tune it, just thought I'd give you a heads up the those orings. Impossible to tune if they are bad.
BW
10-11.5 is factory setting and I have not had to ajust mine. it launches of the start. my problem is at higher rpm with wot it is bogging down and sputtering. i just replaced the high needle o-ring. it was impossible to find, had to get it thru work and only came in a pack of 100. high speed needle settings are 3-3.5 (factory) I have to get a temp gun so i don't know temps but i think it is a little rich right now. I'm at 3-1/4 on the high needle.
I have a Wasp .26 i think it is the same as the picco.I have my LSN 10 1/2 turns out seems to work for me.
