$Revo_Racer$
- Racing
Iv'e put around 4 gallons through my picco .26 max now. I stripped out the button head?, where the glow plug goes...so I took apart the engine and it seems to have some problems.
First, the starting shaft seems to be loose. I could easily slide a piece of paper into the opening. Should I replace the starting shaft or the back plate??
Second, there is a lot of play between the flywheel and piston. I can turn the flywheel that much without it moving the piston. Is this normal or does something need to be replaced?
