Picco .26 carb
Bkyd Basher
Stamford Ny
Hey guys I am having issues with my picco .26 carb slide sticking. I believe the o ring is damaged and binding up. Anyone know where to find just orings for that? or ones that will work?
so upon further investigation I did find there was no oring on the slide barrel and just on the lsn. So I ordered 2 new sets but the only thing I could think of was a little dirt binding it up. Took it all apart and cleaned it all up and gave it a little lube and now gonna hope for the best I guess!
Just for curiosity sake, did you use Green Slime on the O-rings?
Is yours leaking from the slide??
I have tried everything to fix it but still after a couple of runs its wet from fuel again
+1 on the green slime, that stuff works wonders
Mine stopped leaking from slide as soon as i installed a bb manifold and pipe using one of racer1966 adaptors. It leaks because of too much back preasure from a small block exhaust system. Plus the bb exhaust opens up the piccos full performance potential and makes tuning alot easier.
