paint protectant??
Lessen
Super Awesome!
Aurora, Ohio (Cleveland)
  1. Racing
Hey guys, I just finished my Chevy Silverado body for my mini-T but I don't know what to spray over it all to protect the paint. I used Faskolor
Usually just a good backing coat should be fine. Since it's an electric, you don't have to worry about the nitro sludge. But if you want a protective coat, I'd get some Fascoat. It's clear and water based just like the rest of the paint. Throw a couple thin coats over everything when you're done.
I've noticed that the Parma Fastcolor, even after it's well cured, will scrape off with a fingernail. For a good hard final covering I've found that a light coat of Pactra window tint spray puts on a hard shell that adds a super protecting coat to the softer paint.
best paint protector that I've found is Krylon , spray it on 24+ hours after you're done painting your body let it set up another day, then you should have a nice "skin" between your car innards and your paint.
Lates!!
-Will-
www.WilzWerx.com
Just remember to keep your window masks on until your final protectant coat is done... The faskoat will even make your windows hazy...
I use Faskolor paints, but make the last color the Pactra sealer as well. Saves a little weight that way maybe.
Thats not a good idea nitro sludge and cleaner will make the krylon paint disolve.
Lates!!
-Will-
www.WilzWerx.com
