scoobydoo2u
hello i am mounting os 18tm on my revo and i want to shaft start it but what will i need i know back plate and starter but not sure what one and also i am useing a trinity pipe will i need any thing to mount it? thanks!
Pull starts also give you a feel for what an engine is doing. If it's flooded, if it's worn out you will know. It's also easier to set the piston at BDC with a pull starter since you can control when the crank stops moving. With E-starters, you have to fiddle with the flywheel by hand to get the piston at BDC.
Regardless what you do, if your using an e-start or pull-start, your requiring the use of a OWB. The OWB is the annoying part, but I prefer pull starts anyway.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGFK3&P=7
You may want to look in to this set up.
I have not used it....but I have been eying it. It is more expensive thatn the alternatives.....but I have heard good things about them.
The one you linked will not fit the 18TM but I believe they have one for it.
This one should fit however I can't say I want to use it. I woud rather stick to the EZ starter.
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXGFK2&P=V
