The first thing you have to do is decide if you are going to grind the fins from the bottom of the block or spend $20 and buy the New Era mount(REV124), which I am using, that works with the TZ. The threaded shaft needs to be cut, leaving 5 threads, so the new clutch nut(traxxas # 4144) will thread on properly.
Transfer the flywheel collet and flywheel onto the shaft and tighten down the clutch nut. The clutch shoes then need to be trimmed so they will fully open without hitting the clutch nut.
Then put on 1 fiber washer, bearing, clutch bell, bearing, washer and E-clip.
I used the HPI # 86164 header but it need to trimmed to clear the pullstart and then bent toward the rear a bit.
Rather than leave the throttle arm in the stock position I moved it down to make the throttle linkage a bit easier to set up.
The T-maxx throttle linkage (Traxxas # 5168) fit just right without having to re-do the brake linkage. You will need to drill a new hole closer to the low speed needle in the arm to allow the carb to open fully.
The throttle linkage needs to be bent and tweeked a little to work properly but it's simple. With the stock controller you will also need to change the throttle to 75/25 and tighten up the brakes a little.
After that it is pretty much done.
