The Slacker
THis is a question and a heads up !
http://www.misbehavin-rc.com/pit-lane/motor-swap/tm-motor-swap.asp
If by any chance there are old maxxers out there looking to swap in a new motor, this is a good article. However I was cutting the crank and noticed that the clutchbell adapter did NOT want to screw fully against the flywheel. I am 99% confident that it was due to the threads stopping on the shaft.
Anyone try this too? Wonder how your experience went. I did not want to cut the shaft any more so I used a small washer to space it from the flywheel. Works good, hopefully won't be a balancing issue.
