didn't know that, I will re-check. more than likely the heli fuel will work better? although the stuff I am using is 30% nitro, I don't think I really need that in a non-competitive car.
I only run 15% nitro with 18% air fuel. As fuel gets higher in price I'm not going to buy anymore. I plan on making it myself. With the 30% your running now you need a head shim. Os is set to run 20% nitro max.
I am not running the 30%, I was asking if I should. I know the heli fuel has a higher oil content.
I have been using the same fuel as I use with the Traxxas 3.3,
I am going to check what the actual oil content is on the car fuel.
hello ,,I hate to mention this ,,,Because you probably did already .Some plugs will light and still not be right .# 1 fix in my experience. The right
oem plug will have the best shot . Heat range and all . and like nitro% and oil like 15 said !
Good luck
