SilentGTboy
OFNA 9.5 Violator RTR
PART #34954- with Force 26, pullstart
COMING IN FALL 2003
The OFNA 9.5 Violator will be available soon. Fast and low, this kit has all the solid performance of the classic 9.5 with considerable improvements. Wider 330mm arms give the Violator greater stability, a larger 135cc tank keeps you running longer, Offset King Pin suspension type for extreme performance, and if that's not enough this kit will ship with the new effortless OFNA Shaft-Start System to get you running in a hurry.
Worried about staying legal? The Violator width is can be altered to race compliance if necessary by simply removing the extra hinge pin holes.
With a superb kit like this you will Violate the competition!
Attention 9.5 owners: we will be offering a conversion kit soon at a fantastic price (yet to be determined) to keep you on the competitive edge! #40100
Features
Larger Fuel Tank - 135cc
Oil Filled Coil-over Shocks
Front And Rear Chassis Braces
Wider arms - 330mm - for greater stability
Arm Length Can Be Shortened
Full Ball Bearing Set
Front CVA's
Fully Adjustable, Heavy Duty, King Pin style Suspension
Three Differentials
Low-profile Radio Tray Box
Force .26 Engine
Hard Coated Kick-up Chassis
And Much More
The OFNA Violator is wider than the standard 9.5, which provides enhanced performance in the corners and landings. Gotta stay flat to win.
The upgraded King Pin style suspension adds a new level of pro performance, while retaining the classic 9.5 C-Hub durability.
For a narrower ride simply cut off the extra hinge pin holes.
