I used my buggy this afteernoon in quite cold damp conditions so it required richening up about 1/4 turn on the hsn. Half way through the first tank it suddenly went very rich and would not clean out then as if by magic it cured itself !This continued to happen during the next tank aswell to the point where it would run very rich and then very lean to lean in fact so i switched off to avoid damage. All this was happening without me touching the needles . Once at home i checked allfuel lines etc for holes i pressure checked the tank checked the motor for air leaks all seem fine. The only thing that did not seem brilliant was the plug (rb # 6) could a plug cause this problem ? any thoughts would be much appreciated
