NPRC East - Cash Days #1 2023 Annapolis MD
johnnydmd
Beer drinker and hell racer
In Memoriam
Build Thread Contributor RC Showcase: 1
  1. Racing
GENERAL RULES​
  • No drinking or drug use on premises
  • No abusive or foul language
  • Cars are not permitted to return through the track
  • No testing permitted off-tree on track – must be done on side road only
  • Cars must pass tech inspection (from 11:00 to 11:30 am)
VEHICLE RULES​
  • Nitro – big or small block permitted
  • Brushless – 2s only
  • Wheelbase from 11.25 to 13.25 (Standard SE sizes)
  • Rubber tire only
RACE RULES​
  • Dry tire – no sticky prep allowed
  • Tire conditioning, cleaning allowed (Simple Green, etc)
  • 10 dollar first round buybacks
  • Cars must be carried to staging area – no driving through track to get there
  • Cars not to be driven back through track/traps after completing race – must be carried back to pit
  • Do not walk through starting beams after run – or your time will get reset
  • Tree is set to sportsman
  • You can touch the center line, but crossing is a DQ (first car to loses)
  • Burnout pads are provided, but you can bring your own. If you use your own, please place the original pad back in it’s original position
STAGING RULES​
  • Drivers have 5 minutes to get to staging once called
  • After burnouts, drivers will be asked by race master if ready
  • After both drivers ready the tree is set, drivers will stage their cars
  • Drivers have approximately 60 seconds to get their cars staged
  • Both yellow bulbs (pre-stage, stage) must be triggered to be staged – the green light at top will indicate “ready”
  • Deep staging is allowed – meaning you can creep forward far enough for the pre-stage light to go out, as long as the stage and green light are lit you are good
  • Once both drivers are staged, you have 2-3 seconds before the tree counts down
  • If one driver is staged, and the other driver is not and the tree begins counting, it will be up to the discretion of the staged driver to allow a restart – only one restart is permitted
  • Red lighting is a loss – no chase is a race
