Novarossi BS21SB tuning?
Buggyracer28
Portland
I got new servos and everything for my buggy and now it went out of tune cuz i needed new servo horns and everything, adjust my brakes, throttle, etc. So now my low end is very sluggish. I tried leaning it out and it didn't work. i think my high end was really lean cuz i was running 330 at the track VERY BAD. i shut it off immediatly. (some guy at the track tuned it for me last week and i think he had the high speed way too high.) I tried to tune it but my throttle screw was messed up. but right when i started my car it went VROOOOOOMMMMM and it wouldn't go down to regular idle. so i had to bump it when the throttle was like full. SO does anyone have the factory settings for the Novarossi BS21SB or an engine like it? is the P5 similar? I'm not sure. I just need some help with my throttle screw and low end. thats all thanks.
I can tune it but i dont know the factory settings cuz the manual that the engine came with was surprisingly lame. I accidentally threw it away. anone got it in acrobat?
if it's revving real high when you start it, then you need to turn down (out) your idle screw.....it's either a screw in the end of the carbeurator slide or a small screw right under and next to your low speed needle.....but if you just changed your sevos I'll bet it's in the setup of your t/b servo...
Thanks. Its not my servos.. i have them perfect. It was the idle screw cuz i put it in like all the way. (stupid...)
DOOOOOH!....it happens....have you ever gotten pissed cause your RC wouldn't start.....you trouble shot stuff and after 10 mins realize NO FUEL.....I'm not sayin I've done that...I was just asking if YOU had?
