nother revo mod, tekno boxes and 250cc tank.
beason
Bash, Fix, Repeat..
Webster, TX
had the tekno boxes, came accross a tank really cheep, so i figured i might as well put the stuff on there....
tekno rx box and batt box saves weight, and 250cc tank will make it run practicaly forever! (clamed 20+ run times with bigblocks)
rx box is big enough to fit a micro rx, big failsafe, switch, and all the wires.
heres the pics!
Looks good, but that radio box doesn't look water tight at all. :(
-Michael
Neat..been wan tin g to get this one........did you have to retune the rig at all using the bigger tank??
Talon
havent ran it yet, i wouldnt think so though, maby a small bit..
Looks like the fuel tank is kinda out in the open. I have been debating this mod for my revo. Is there a skid plate that goes under it?
havent found a skid, wish it had one...
i run an illusions body and it fits very snug on the tank, but its super thick so i dont think it will get hurt. ill let you know soon!
i got the tank from a user on another forum (revo forum, NOT traxxas!) its a tank for the hyper one seven. its 250cc's
no. the reverse setup, and modual will have to be removed, most people do the foc anyway, so this isnt a problem, however the rx box is pretty big. the rx, (micro 2 ch airtronics) switch, and failsafe all fit.
i changed this up a bit, used a different tank. the 250 was to big, the cap seal leaked, and the truck would lean out in high speed corners.
here are some pics with a mbx5-t tank, it fits WAY better, and its about 160cc's. still big enough..
yea i guess i spelled it wrong, module (sp)?? ether way olds is right, the optidrive unit.
to do the 250cc tank mod w/ Tekno RX/battery box? Probably. I just put it on my revo (the tekno parts, stuck with the stock tank). the box itself is REALLY big (much larger than I thought it would be) you may be able to stick the optidrive in there, if you picked up a smaller reciever than the stock. I'm runnin a HiTech XXL 2-channel reciever, and theres PLENTY of room in the box can't say for sure if you used a 3-channel reciever tho.
Mike
Sweet mods on the Revo. If you have some aluminum sheet and a dremel, you could probably fab up a skid-plate for the tank. Just use some Shoe Goo to hold it to the tank....
most people remove the optidrive when they do the foc, no reverse = optidrive.
