- In my recliner
- Flying
If you are running Windows XP and have Norton System Works installed on it, you might be wondering why your computer suddenly runs dreadfully slow from time to time. Since I have some of Norton's sensors on my desktop, I can see at a glance how much RAM is available, CPU usage, percentage of hard drive fragmentation, etc. When programs slowed down I noticed that CPU usage was in excess of 85-90% without any reason for it to be that high.
In XP, hitting Ctrl, alt, del will bring up a window showing what's running and the percentage of CPU resources it's using.
NOPDB.Exe was the culprit. I did a search on it and found it to be part of Norton, starting without warning and running at the most inopportune times, checking the percentage of hard disk fragmentation. It usually runs 2 to 3 minutes, causing your computer to drag.
To stop this annoying slow down, go to Control panel, Administrative tools, Services, and locate 'Speed Disk Service'. Double click it and disable it. Changing it from automatic to manual does not stop it from running.
If you use Norton to defragment your drive, (much faster than having Windows do it) you need to restart it in the same place before you can run the defrag. When it's done, go back and disable it.
