Tarant
I was finley able to get my savy .25 running. and after a few minutes of tinkering I could not get the temps down. I had all needles flush and the engine was reving high enough to engage the clutch 250. I turned down the idle and it stopped the wheels from turning but it was still reving pretty high, so I was fed up. I took off the fuel tube that was connected to the carb and attached the roto start and turned the engine over for a few secounds, and no fuel came out, no matter how long I had the roto start going no fuel was coming out of the line, I cleaned all the fittings, and replaced the line and cleaned the pipe. but it still had like no back pressure.I am guessing that if their is very little BP then not a lot of fuel would be getting to the engine causeing it to run lean.
I took out the uniflow cause I thought that was causing problems but no luck.
anybody have a idea of whats going on. I am so fed up with this damn engine.
