Nitro start up help needed
jasonc0902
Hi I have a .21 Schumacher XTR. I tried to prime it carefully and when I pulled the cord, it did not retract. Any suggestions to fix would be appreciated.
:cheers: JC
You pulled it a bit tooo hard. You'll have to open the casing of the cord and it should retract itself.
or, try spinning the flywheel... doesn't that thing have the dual action starter? The pull start and the drill start... like the mgt?
Only if it's using the TTR Pro21R. Well actually, it's supposed to have the EZ start system on it that uses a 12v drill. There's no pull start with that engine if it came from the factory.
